Widest tire?
Tallguy26
South Carolina
2018 jeep wrangler, 2022 jeep cherokee, 2023 f150
Hello, I am wanting to put a set of 22s on my new regular cab. The goal is to eventually lower the truck. I was wondering if I could run a 285/40R22 or 305/40R22 without rubbing. The wheels I am looking for are 22x9.5 with 25mm offset and 6.2" backspacing. Thanks for the help.
Discount Tire
Arizona, USA
Website
discountti.re
All Things FORD
Tire & Wheel Specialists
Hello,
There aren't really any options in a 285/40R22, and the 305/40R22 is really to wide for the 9.5" wheel.
I might recommend a 275/50R22 or 285/50R22. Both will be a tad shorter so, depending on how low you go, they should tuck nicely.
Tallguy26
Tallguy26
South Carolina
Thanks I was looking at the nitto 420V main thing I was concerned about is rubbing on the rear shock or during full steering lock. With going with a taller tire will I have to have the computer reset for the tire size or will the truck do it automatically?
Discount Tire
Arizona, USA
Website
discountti.re
All Things FORD
Shouldn't be an issue. What wheel are you looking at? I will double check fitment for you.
Discount Tire
Arizona, USA
Website
discountti.re
All Things FORD
I did check, fitment and availability is good. I can assist with an order if you would like.
Tallguy26
Tallguy26
South Carolina
I'll have to get back with you on that. Not quite ready to order yet. Thanks.
