SALEEN961
- Joined
- Jan 1, 2023
- Threads
- 12
- Messages
- 653
- Reaction score
- 876
- Location
- Radnor, PA
- Vehicles
- 2021 F150 XLT 302A
- Occupation
- Automotive Technician
https://torsen.com/tbr-lube-friction-modifier/
Bringing this all back around to friction modifier – the actual function of modifier (the “modification” it makes to the friction) is that it brings the static coefficient of friction down to a similar level as the dynamic coefficient of friction. This helps smooth out the transition from static to dynamic friction, getting rid of the tendency for abrupt stick/slip. This, as a result, largely eliminates the chatter or squeak . However, it does this at a price – the price of lowering the coefficient of friction for the whole system.
So, if we return to the notion that the differential is a friction device, it then stands to reason that the friction the differential generates is directly influenced by the lubricity of the oil blend that is used in the system. If the oil’s friction properties are reduced, the amount of friction that the diff produces is proportionally reduced. That, in turn, has the same affect on TBR. Usually, it is a small but measurable amount, maybe up to a 10% loss of TBR.
