What is this connector for?
Doyouevenboost
Brian
Minnesota
2002 Subaru, 21 f150 502a ecoboost
Utility maintenance worker
Do all F150's have this wiring? Don't have a subwoofer, looking at adding one, it would be easy if the wiring is already there.
I can’t speak on that. I do know there is more than one p# for that harness.
grosbiz
Justin
Gatineau, Qc, Canada
2008 Toyota Yaris Hatchback, 2015 Nissan Rogue
I remember seeing the Wireless charging pad in the console connecting to the back of the rear seat.
mwooly
San Diego CA
2002 BMW E39 M5, 2021 Ford F-150 Lariat
Engineering Management
Power sliding window?
No. It isn't for the power rear window. I have a power sliding window. This connector does not connect to it. I am wondering if it is for heated rear seats. I remember reading somewhere that the higher trim packages have them.
mwooly
San Diego CA
Apparently Ford doesn’t know what it is either..
Thanks for looking into this. Since the dealership hasn't gotten back to me, I am guessing that it also does not know. Interesting. Given the 12VDC on one of the pins that is fed by a relatively large conductor, it is a good bet that it is not just a signal cable but it is meant to power something.
daemonic3
Terry
Sacramento, CA
2017 F150 3.5EB
Good guess! If it was thick then it must be to supply something hungry like heated seats. I have a KR with heated seats, I will see if mine is connected tomorrow (if no one beats me to it).
Doyouevenboost
Brian
Minnesota
Connector C3134 lists that it’s the heated seat connector. I would still check your KR though to maybe figure out this mystery! ?
mwooly
San Diego CA
Nice work! Where did you find the listing for the C3134 connector?
Doyouevenboost
Brian
Minnesota
I used to be a Ford tech, and I still have friends in who may or may not give me access to workshop manual/wiring diagrams. ? I still am not sure if that’s the original connector you were looking at.
Knickell
Mazda Protege, Ford F-150
Sure,, just plug anything u want in there I'm sure it will be fine, then tell the dealership what u did so they can say that's fine too! That way your warranty will be updated...
This dude gots jokes!
Knickell
Something for the stereo? Looks like its near the amp behind the seat.
onlythetoast
Jason
Miami
2023 F-150 Lariat
I am going to install a dash cam with a rear window camera. I think I'll go with the Rexing V5 and the plug and play rear camera.
Any way, I have been looking for any easy to access 12DVC power source that is switched on with the ignition. I found this unused connector behind the rear crew seat. The brown wire is relatively large-gauged and is 12VDC, switched. It is part of the same harness that feeds the amplifier. Its location is convenient because it is easy to get to and it allows me to run the wire from the dash cam to it along the headliner along with the wire that will connect the rear camera to the dash camera. This seems a lot easier than trying to snake the power wire down a pillar, through the dash and to the OBDII or through the fire wall to the fuse box.
Before I do this, I want to make a sanity check. Anyone know what this connector is used for? Will using it cause an an issue?
It's for a Police Dome Lamp DB5Z-13776-A
