Using factory Sub connector to add kicker 11HS8?
bhamilton
Massachusetts
2023 F150 XLT PowerBoost
On my 2016 Screw I was able to utilize the factory connector where the OEM Kicker Sub would plug into to wire in a Kicker 11HS8 powered sub and enable it via Forscan. Does the same exist on the 2023 non B&O?
If so, where's the connector, what do I need to plug into it and what do I need to enable in Forscan?
If not, what are my options for plug/play install?
Thanks!
JustinH
Justin
Wisconsin
2023 Ford F150 XLT Powerboost
Computer Engineer
Bumping this because I would also like to know.
Lricaud81
Louisiana
2023 f150 stx fx4
O that'd be nice if it was possible.
Kanuck
Winnipeg, Manitoba
Retired Electrician
I just downloaded this from PTS, 2 minutes ago, as I was looking into adding factory sub to my 21 XLT.
Lricaud81
Louisiana
2023 f150 stx fx4
Dang you gotta use fdrs for that. And I'm over here scared to use FORScan. Lol
Kanuck
Winnipeg, Manitoba
Retired Electrician
FDRS steps you through the process one step at a time. Looks daunting but it is not bad. There are enough members that would help you through it.
