Upfitter Switches - they are on the tremor, I want to add them!
anson
F150 Supercrew
Plumbing Upfit
I think this could be done with previous generations.
Anybody know how to get the part numbers needed to install on a non-tremor?
CaptainAmericaRob
Rob
2021 F-150 Lariat FX4 PB
Machine Designer - Ford Motor Co.
I'd like to add them as well. It will take some serious work of running wires from the switches to power and a fuse block to hook up your accessories too.
I'm not sure you could get the factory wiring and fuse panel, as i'm pretty sure its wired into the existing wiring harness.
anson
F150 Supercrew
Plumbing Upfit
look forward to figuring this out. If I can get some part numbers and wiring Diagrams, should be able to figure it out.
jeffcrum
Lake Saint Louis, MO
Computer programmer
Are these the overhead switches? Might be easier to just add new ones to the lower left or right dash near your knee.
anson
F150 Supercrew
Plumbing Upfit
Yes. And yes, aftermarket would be simpler and probably cheaper, but I prefer to have the factory look as much as possible. Seen too many ugly switch installs.
Whoskyle
AZ
2021 F-150 XLT
Did you ever figure out part #?
Pedaldude
Arizona
There's a tutorial on another F150 forum for the previous gen. I believe using Superduty parts. Hopefully soon the information for the 2021+ trucks will be available as well as part numbers and wiring harnesses.
NoReins
Pennsylvania
have you heard anything back from boosted?
They said in a few weeks it should be on the site, but with just like everyone else, cant get supplies right now
He custom makes the wiring harnesses, and you have to purchase the upfitter switch elsewhere.
Infotroll
NH
F 150 2022
anson
F150 Supercrew
Plumbing Upfit
I want also wan the stock look and waiting on this so I can install lights and a couple of others goodies .Here is what I got so far in term of resources and info some threads from different forums Just scroll down to till you see what you like. I may do stock switches and aftermarket fuse panel but who knows yet
1. he has a nice fuse panel all wires are labeled .
2. stock part numbers
3 boostedgreygoosedesigns mix of stock and after market maybe the best
Thanks for the info!
SkiZ
Francis
Quebec, Canada
Ford F150 lariat 2021
Construction worker
Still nothing in 2023 :(
Big Cam
Nick
North Dakota
2022 Ford F150 Tremor 402a
Support Engineer
