Unable to remove Seatbelt chime
Medic3166
US
2025 F-150 STX SuperCrew
I tried disabling the seatbelt chime as instructed in the owners manual & it didn't work.
Tried disabling it in forscan using the method in the spreadsheet and that didn't work either. Am I missing something or did they disable the option for 2025MY?
Meterman
Medina OH
2024 F-150 Lariat PowerBoost 7.2Kw
I was able to disable the chime in my 24 Lariat. I don't know if they changed anything on the 2025. I wanted seat belt chime and alert on dashboard gone too.
Here's my changes.
Disable driver & passenger seatbelt minder
Disable seat belt indicator light on dash
Disable Start Up Chime
BEFORE
IPC​
720-13-01
720-13-02
720-14-01
720-14-02
F100
0120
2000
0000​
0001
207D
0000
003D​
80AD
005C​
2/7/25 CHANGED WITH IPC MODULE USED AS BUILT FORMAT
AFTER
IPC​
720-13-01
720-13-02
720-14-01
720-14-02
0000
0000
0000
0000​
0000
003C
0000
003D​
003B
003C​
I CHANGED ALL TO 0 AND FORSCAN MODIFIED OTHER DIGITS AUTOMATICALLY
Backup Warning Chime (BWC) • Driver Beltminder (DB) • Pass BeltMinder (PBM) • Mid Pass Beltminder (MPB)
IPC​
720-01-01
xxxx​
xx*x​
xx--​
DID NOT CHANGE ON 2024
Disables door ajar chime BEFORE
IPC​
720-01-02
0227​
90E3​
Disables door ajar chime AFTER
IPC​
720-01-02
0207​
92C5​
The C changed from E by itself
Powerboost_Law
Pat
Alberta, Canada
03 SVT Lightning, 64 Vehicle misc Ford Fleet. 2023 F-150 Lariat 6.5 Box Powerboo
Law
The procedure changed in 2025, don't use the same procedure as previous years. I just used the instructions in the owners manual, the new procedure doesn't involve waiting for the seat belt light to go out, you just run the buckle in and out I think it was 5 or 7 times then the light flashes then.
Medic3166
US
Tried it verbatim from the owners manual. Still doesn’t work.
Powerboost_Law
Pat
Alberta, Canada
Law
You have a very unique problem, I would need a Vin to check if you need updates, short of that you will need to see a Dealer.
Medic3166
US
The funny thing is the manual from Ford’s website pulled up from the VIN, and the manual on the screen in the truck have different instructions.
Ford F-150 Unable to remove Seatbelt chime IMG_2342
Ford F-150 Unable to remove Seatbelt chime IMG_2341
LogYZ450
Utah
2025 F-150 Lariat
RF Systems Test Engineer
I just had luck watching the airbag light next to the seatbelt icon. Just leave the messages alone (big boxes that pop up) and immediately start the plug and unplug sequence. The cadence should be 1 second intervals. Plugin 1sec, unplug 1sec, plugin 1sec……… I reached 6 sets before the seatbelt icon flashed and it worked. BUT I tried it again and it took 10 times. So if you are running into issues just keep doing the plugin and unplug sequence until you get the flashing. Cycle the ignition after and you should be good.
CAD_Jockey
Dave
NC
2025 Ford F150 STX Supercrew
Design Engineer
Starting the seat belt in/out sequence as soon as the airbag light goes off worked for me. I previously tried ForScan, and like the owners manual said, with no luck.
Medic3166
US
Just an update, as other mentioned I was finally able to get it by starting after the airbag light went off. Also, I wasn’t unlocking and clicking the seatbelt fast enough
