Turbo gauge?
ToddnTX
Todd
19 Dodge Durango, 07 GMC Sierra. 2021 Ford F-150
I’m new to fancy trucks with turbos and what not... I have what appears to be a turbo gauge on my instrument cluster that I’ve never seen move or change..
can someone explain to me what this measures or how to use it?
Thanks.
Ford F-150 Turbo gauge? D8DAC6C9-B887-412F-886F-2CE8A4AB1296
Dan M.
Dan
Ruskin, FL
2021 KR SQ 4X4 PB
Retired Army
Put your pedal to the medal and you’ll see it move. If you drive like me, it’ll hardy ever see it move.
KBKEITH
It measures the boost your turbos are making in pounds per square inch. (PSI)
Tosh
Willamette Valley, Oregon
2021 F150 Lariat Powerboost, 2024 Mach E Rally
Re-Tired Bicycle Mechanic
It measures the increase in intake manifold pressure created when the turbo charger is adding boost. As stated, if you don't put the pedal to the metal, you may not see it move at all.
If you pull a trailer, you should see it registering boost.
Since the boost is computer regulated, this gauge is not really neccessary, because the computer will prevent over-boosting (just like it will prevent over-revving).
ToddnTX
ToddnTX
Todd
Thank you!
And I did just test ITC when I mash the gas it shoots up.
thought for a second there I had to inflate something lol..
jeffcrum
Lake Saint Louis, MO
Computer programmer
Mine moves a lot!
And, OP, thought you had to inflate something ... H I Larious!!!
mrtrav
Travis
SW WA
2021 F150 Lariat Sport
I dont see this on my cluster, is there somewhere to change what gauges are shown?
maxinike
Stephane
ontario
f150 powerboost, ranger 2020 and lawn tractor
make this gauge move..or turbo gonna seize..
Twilighthan
Twilight
Austin
I don’t even use a boost gauge when I’m on the race track in my AMG. Couldn’t figure out why it was there in a truck. Whether I’m pulling a trailer or not, it shows me the boost working.
wayfarer556
Austin, TX
2021 F150 XLT Powerboost 302A
Put on the Sports mode and haul ass, and you will see boost engage a lot more often.
Knickell
Mazda Protege, Ford F-150
It measures the boost (PSI) that the turbos are generating. If you’re a feather foot, you won’t see it making too much boost (if at all) that often.
