Truck not detecting key fob
XLT Lariat
Tom
NC
2024 F150 Lariat
The door handle lock/unlock does not work for either Fob. When I get in the truck I can start it, but then a message in the dash pops up stating, "key fob not detected". Have tried BMS reset, and reset the fobs. Truck is less than a month old. Any insights? Hate to take it to a dealer already.
Thanks for the help.
Stormpeakco
Dave
Colorado Rockies
'18 VW Alltrack, '25 F150 KR (order)
Wow.
On a previous '14 DDurango and our current '18 VW Alltrack both out of the blue, a similar issue would occur and the owners manual would say to place the fob next to the steering column in a particular place ("reboot" the fob-software recognition?)..seemed to occur more w/ the winter, cold temps.
Ziggy73
Keven
2021F150 Powerboost
Radiologic Technologist
You wearing blue jeans or heavy pants? Mine does that sometimes when I wear those types of pants and the fob is in my pocket. Also, not sure what year you have could have low fob battery.
Kanuck
Winnipeg, Manitoba
Retired Electrician
When it happens, put the fob in the "PROGRAMING SLOT" in the cup holder. Does the truck "SEE" the fob then? I would change the batteries in the fobs, 2032's. Does this happen at home? I have a dead spot where for some reason, the truck can't read the fob. It is at a drive up teller. I have to put the fob into the programing slot, even when the truck is running, to put it into gear.
Groovicles
2022 F150 XLT 302A PB Max Tow
Finance
I hate to ask the obvious, but did you try changing the battery in one of the fobs? The same thing was happening with the fob I always use on a different vehicle, and once I changed the battery it worked fine.
Stormpeakco
Dave
Colorado Rockies
Yeah, my (new) routine for the past 4 years is to change them out and check pressure in all spare tires @ 2 years (don't ask me why).
Sojourner
Maryland
2023 F-150 Tremor
Retired Army / Disabled Vet
This (i.e., "key fob not detected" message) happens on all three of my new-ish Fords (at least 1-2 times per month on each).
I'm using aftermarket fobs for them so that could be part of the problem.
Having said that, my fix is easy. When the message pops up I press the lock button and then the unlock button on the fob. Message disappears. Problem solved until next time.
XLT Lariat
Tom
NC
2024 F150 Lariat
Thanks for the feedback.
XLT Lariat
Tom
NC
2024 F150 Lariat
Good system
Have not changed them. Wouldn’t think i need to because all other functions work and the truck is so new.
XLT Lariat
Tom
NC
2024 F150 Lariat
I have put the keys in the program slot and did the reset process. I will change batteries and see if that fixes the issue. Both fobs have the same issue and happens anywhere.
XLT Lariat
Tom
NC
2024 F150 Lariat
Pickup is a 2024. Will replace batteries and see if that helps.
