Transmission Issue Advise
merc
James
Alabama
TBD
I brought my truck in to get the insulator recall done (just rivets) and I asked the service advisor to have the tech check the transmission. The transmission has always been very clunky and shifted rough in most of the gears. I would also get a bang after coming to a stop on a 3 degree or more decline after letting off the brake to start going again. I have about 5k miles on the truck now and I figured it would eventually stop after it was broken in however, it has not.
The tech drove it and identified the same issues. He checked the transmission fluid level and said it was low so, he filled it with 2 qts of trans fluid. I picked up the truck, drove it home, and as soon as I parked it in the garage I noticed light smoke from the engine bay. I popped the hood and could see it was coming from the back of the engine toward the firewall. I looked under the truck and saw a large puddle of red fluid and it was also all over the bottom of the truck. I dropped it back off at the dealership. They called me today and said they found a leak between the transmission and transfer case and said the output shaft seal needs to be replaced.
Do you think they are BSing me and are trying to avoid looking into the issue further? It wasn’t ever leaking and after they filled it, it started leaking. Any advise or things to mention to them would be very appreciated.
2021 F-150 FX4 5.0, October 2021 build
imnuts
Dirty Jerz
'21 502A Powerboost 4×4
Facilities Engineer
It could have leaked and you were running with low fluid for a long time. They add fluid, and now you found the leak. It could also be that they added to much fluid, and when it heated up and expanded it blew the seal. Hard to tell really. I can see where low fluid would give you rough shifts though.
merc
merc
James
Alabama
TBD
The truck is always parked in the garage when not in use, I'm very confident I would have seen transmission fluid if it was leaking.
I think you're right, they probably added too much and it blew the seal.
Ford Motor Company
Official Ford Account
Ford
Dearborn
Good morning, James! Could you please send us a private message with your VIN and dealership information? I would like to look into these transmission concerns for you on my end. Thanks!
jdr
Jim
IL
2021 F150 XLT 3.5EB
Retired Fire / EMS
I'm having a similar issue. The transmission surges when shifting from 5 to 6. I also have the bang when it is down shifting moving from 3, 2, 1.
merc
merc
James
Alabama
TBD
went to pick it up yesterday after they replaced the seal…there was trans fluid below the truck, so it was still leaking. Unbelievable.
Boston
2021 F150XLT 2.7
if it was over filled, it would take longer than just driving home from the dealer to blow the seals just my 2 cents
jdr
Jim
IL
2021 F150 XLT 3.5EB
Retired Fire / EMS
l found it interesting, there is no longer a 'dip stick' for the transmission. We, as consumers, can no longer check it's level.
Ford Motor Company
Ford
Dearborn
Hello!
Send us a private message with your VIN and the name and location of your local Ford dealer.
I’d be happy to see what I can do to assist with this transmission concern on your F-150. Thanks!
jdr
Jim
IL
2021 F150 XLT 3.5EB
Retired Fire / EMS
Hello!
How does one send a 'private' message.
Mtnman1
Tod
2022 F150 RCSB FX4
Been like this for a long time. Wife had a Chevy HHR with no tranny dipstick. This was over 10 years ago.
Bryan Simon
Bryan
San Antonio, Texas
Maintenance
It does have a tiny dipstick it's just a major pain to get to
something like this
Must be noted.
Do not remove that plug/dipstick UNLESS the transmission is warmed up and the engine is RUNNING.
you will end up with transmission fluid everywhere except in the transmission.
jmargo
Nor-Cal
2021 F-150 Lariat PB
Thinking they overfilled it. The chance you were 2 quarts low after 5k miles with no visible leak is doubtful.
Henfield
Usa
I just saw a recall for transmission fluid low on my Late Oct/Nov built 21. It was reported by the FordPass app.
bizarrely, when I looked at the app a second time, recall had disappeared.
