Transfer Switch install - success!
JoeRedFly
Joe
2023 F150 PB
Working
And you eliminate your whole grounding system. It’s wrong
You are wrong or misread my post. House ground system is left unaltered, this is the same way utility power is provided to my house. The power company does not provide the ground, it's part of your house wiring. All of my appliances are still grounded through the house ground.
Perhaps you could provide some intelligent counterpoints and a drawing showing why this grounding method is dangerous?
Gros Ventre
Western Wyoming
Read my post on "The Green Screw." It's a few posts down. For those house whose wiring system has the Neutral Ground bond in the breaker panel (some utilities require it to be elsewhere) there is a "Green Screw" in the panel. That is the neutral ground bond point. Remove that screw and you have no need of a transfer switch. The ground remains intact and includes your truck. You must have used a 4-wire cable and plugs along with an interlock plate in your panel. The neutral remains intact.
Check your local codes.
