Trans cooler for 10R80
Nighsight
Tim
N. Cal
2021 F150 Powerboost
Anyone see or heard of a cooler kit specifically made to be installed on the 10R80? I don't like the temps that my Powerboost tranny reach. I know 210s to 220s are normal for this transmission, but I'd like to lower them a bit. On tap is changing out the pan as well so that routine ATF changes are easier. I plan on keeping this truck for a long time and this and the coolant temp are the two things I'm going to attempt to improve.
JohnMcClane
Lower 48
I know this was posted a while ago, but this was something I actually wanted to ask if anyone had been running a while ago…
https://yourcovers.com/pml-ford-10r80-deep-transmission-pan.html
They make a “stock” depth as well that should fit Powerboosts (I would confirm with them first though).
Pretty confident the stock pan on the 10r80 is plastic, so you should automatically get better heat dissipation from the aluminum pan, extra capacity pans(if they fit) will also keep things cooler.
Last suggestion, run RP Max ATF when you swap the pan.
There’s more that could be done, but that should be adequate for most applications.
