Hmmm, ok, but what mirrors are you talking about? Are you talking about the 360 Camera view that uses all the cams, including the ones in the outside rear view mirrors? And that view is off?the actual view on the screen display. my apologies for lack of explanation.
Ah, so this has to do with your 360-degree cams display, not your trailer tow mirrors per se (the side cams happen to be mounted in the non-moving base of whatever mirrors are installed).the actual view on the screen display. my apologies for lack of explanation.
yes that is correct. they are fixed to the base of the trailer tow mirrors.Ah, so this has to do with your 360-degree cams display, not your trailer tow mirrors per se (the side cams happen to be mounted in the non-moving base of whatever mirrors are installed).
Please post a pic of the "off center" display to illustrate your problem.
Ah, thanks for the pic, now getting closer the the specific situation - this relates to the Trailer Reverse Guidance split-screen view in particular? No other views?notice the position of the mirrors on the screen.
