JEB
Right. What did the gray (not orange) pop up show at the gas station when you checked the brake controller setting and saw the gain was at 10? Did the controller indicate that the trailer was still connected? If it did, you may have found a different problem. What was the braking effort setting? Low, medium or high?Turning on headlights is one of first things I do. RV camera will only come on if lights are actually turned on, auto does not work.
Also, remember that the controller is designed to reduce brake output at slower speeds—around 11mph—so they likely would feel spongy at a gas station. From p. 406 of the owner’s manual:
“Note: The trailer brake controller reduces output at vehicle speeds below 11 mph (18 km/h) so that trailer and vehicle braking is not jerky or harsh. This feature is only available when applying the brakes using your vehicle's brake pedal, not the controller.”
