"Trailer Brake Module Fault" Message Won't Go Away
Smitdog
2021 F150 Limited PowerBoost Smoked Quartz
Gainfully Retired
I connected a boat trailer that had some really old / frayed wiring. Connected trailer's 5-way into truck's 7-way adapter, all worked fine initially. Eventually trailer wiring frayed off completely or shorted out, and I received a "Trailer Brake Module Fault" message on the dash.
No big deal, or so I thought. Disconnect trailer, and hit "OK" on message. Didn't work. For the past week I get the error message everytime I start the truck. Also of note, I have a "fast" blinker indicator sound, but all blikers are flashing at normal speed.
In an effort to clear the message, I went so far as to delete the associated trailer profile, checked all fuses related to a trailer (highlighted in red), and disconnected the battery for 10 minutes. Still get the error message and fast blinker sound.
I've read on other forums that disconnecting the battery for 20+ minutes has cleared the fault. I disconnected for 10 minutes, thinking that should be sufficient... But perhaps not long of enough time?
Any ideas? Seems like it would be a simple process to reset / clear.
Ford F-150 "Trailer Brake Module Fault" Message Won't Go Away Trailer Brake Module Fault
#42 Trailer brake control module
#55 Trailer tow park lamps
#56 Trailer tow stop and turn lamps
#58 Trailer tow backup lamps
#91 Trailer tow light module
#107 Trailer tow battery charge.
Ford F-150 "Trailer Brake Module Fault" Message Won't Go Away Fuses
Smitdog
Smitdog
Gainfully Retired
Bump... No one else experience this issue?
Any advice on how to correct or clear the fault?
Really hate the hassle and time involved of taking the truck to a dealer for such a minor issue. :rolleyes:
hera87
Hernan
Salt Lake City
I have the same issue: trailer fault message and rapid blinker indicators. My issue started when the battery died randomly one night. I jumó started it and everything is working great, except for this weird software glitch. Did you get it resolved?
Smitdog
Smitdog
Gainfully Retired
Still have the issue, have not found a way to clear it, I've just been ignoring it. I don't know a way to clear it without taking it to the dealership, which is a hassle. Also today my dash started rebooting several times for no apparent reason... It did this about 2 months ago but it only lasted for a few days, so I don't know what's up.
shtraver
Shane
Ontario, Canada
2014 f150 FX4, 2021 f150 lariat sport 5L
Have you checked all the fuses? Maybe you blew a fuse?
Smitdog
Smitdog
Gainfully Retired
I checked all the fuses, even disconnected the battery for 10 minutes.
LUV2FORD
Tulsa OK
2021 F150 Platinum 6'7" bed, loaded. 6" BDS Lift
I just got same issue. Blinkers work normal on outside but I get the fault message and quick blinking on dash.
Smitdog
Smitdog
Gainfully Retired
Was this related to anything having to do with hooking up a trailer connection?
Jrihn47
James
Vervinia
2018 Ford F-150 5.0
Military
It’s happening to my 2018 now. I disconnected my camper and the fault came on almost immediately. Hooked the camper it back up and the module is not working any more.
LUV2FORD
Tulsa OK
I've never hooked up a trailer yet, but just had it happen. Seems very odd. Nice warm day. Drove to restaurant and it was fine. Came out from restaurant and it wasn't.
I disconnected the fuses shown in red in first post and then reinstalled them. I could here something clicking when fuse was pulled. The error message cleared! Hope it stays that way...... ?
Bogeypro
Preston
Huntsville, AL
2021 F150 XLT
IT
Yes!! I had that. It sucked. I never got it to stop binging over and over and over. I could jiggle the connection... It would stop for a while then come back.
Smitdog
Smitdog
Gainfully Retired
What connection did you jiggle?
Cocheran
Justin
Oklahoma
2021 f150
Eye doc
I had this happen last week after hooking my old trailer up.
fast blink. Module fault warning on start. Also had no out put to trailer lights after it started.
i pulled the fuses i saw that said tow.
i kept updating this thread for new info.
Unplugged battery this morning.
everything still has power with the hybrid ??‍♂
Then i noticed the fuses at the top of thread.
i hadn’t seen #91 fuse.
i pulled it and it was blown.
i put a 20amp fuse from the aux port in there and all is back to normal.
I’m so glad. So i registered to let y’all know.
LeadFoot-Lariat
Oakville
21 F150 Lariat
Hi my trucks a week old with only 160kms,and I’ve had the bcm module replaced and now waiting on the trailer Module now and I haven’t even towed anything…
Smitdog
Smitdog
Gainfully Retired
I had pulled and checked all the fuses I thought might be related, but evidently my old eyes can't tell a blown fuse from a good one!
I tried buying a new fuse for #91, but it's one of the new-fangled fuses and every auto parts store I checked didn't carry them; they told me I had to go to a Ford dealer.
So I pulled a similar 20amp fuse from #34 "Auxiliary Power Point", put it in #91, and bam, "Trailer Brake Module Fault" message and faster blinker issue went away!
I ended up taking the #91 fuse apart to see if it was really blown, and it ended up falling apart, but I'm sure it was blown, just not easy to see with the opaque semi-clear plastic over it.
Now I'm trying to find out where I can get spare fuses of this type, but can't determine what "type" of fuse this is. Have been reviewing the info here:
https://car-fuse.blogspot.com/2020/12/2021-ford-f-150-fuse-panel-diagram.html
Anyone know the type of the fuse in the image?
Ford F-150 "Trailer Brake Module Fault" Message Won't Go Away 2021-08-25 14.13.07
Ford F-150 "Trailer Brake Module Fault" Message Won't Go Away 2021-08-25 14.29.08
