BruiserNL
- First Name
- Stephen
- Joined
- Sep 14, 2023
- Threads
- 3
- Messages
- 13
- Reaction score
- 0
- Location
- Newfoundland Canada
- Vehicles
- 2022 F150 XLT
Good day everyone. On my 2022 f150 every time I plug in my 7-pin trailer and start the truck I get the message stating trailer battery not charging, see manual. The only way I seem to be able to get this to work is to start the truck, get out and unplug and replug the seven pin every single time that the truck is restarted. I have tested the pins at the back with a voltmeter and I also test inside the trailer at the bus bar. Nine times out of 10 I never get power to the battery for recharge, once in awhile it will start without this message and power is going to the back.
I have had it into the dealer they can't seem to find anything wrong. It's so frustrating that every time I start up I get this message. Quite often even when no trailer is connected I will be prompted to select a trailer. Quite often with no trailer connected and I put my truck in reverse I will get the message reverse brake assist not available.
Stuck for what to try next.
Has anyone found a fix for this? I see lots with similar faults.
