Tire pressure for bigger tires?
timnohio
Tim
2024 Ford F150
What is everyone running with their bigger tires ?
This site says my tires (Toyo Proxes STIII 305/45r22 should be running at 31 psi.
Does this sound right?
Ford F-150 Tire pressure for bigger tires? Screenshot_20240710_151301_Chrom
nikon858
Justin
Jupiter, fl
23’ f150 platinum powerboost
31 is way too low. I have the same size but a Michelin defender and I have 42 in the front 40 in the rear. I tried with 38/37 and my gas mileage went down.
Calson
Monterey CA
2022 F-150
I would start with the factory recommended tire pressures and then check the wear pattern after 1000 miles and make adjustments. I would never go by the tire manufacturer's website information as it is tire specific and not vehicle specific. The "chalk" test is also worthless and only a visual inspection of the wear pattern if fool proof.
timnohio
timnohio
Tim
2024 Ford F150
That's pretty much my opinion until I saw that website. But I'll continue to keep them around 35 psi.
diambo4life
OKC
2022 Lariat Screw 4x4
Assassin
35psi in my current 275/70/18s and what I ran in my old 33x12.50x18 tires (below)as well. .
Ford F-150 Tire pressure for bigger tires? 0R5A2155 (2)
labjr1
Louie
Nashville
2023 F-150 PB Platinum
IT
Feel free to run lower than the manufacturer recommends as long as you are not running 90mph down the highway and building up heat. You will get a smoother ride and better performance. I ran 42"X17" Maxis Trepador Stickies on my Jeep. Manufacturer listed them at 35PSI. I ran them at 15 PSI on the street and 3-4 PSI on the trails. The physics behind the larger contact area and distribution of weight dictate you can run lower pressure.
Cooter
Butch
Maryland
2023 F-150 STX - 2017 Expedition XLT - 2006 F-150
US Government
I am running 295/60 R20's, they have been @ 40 PSI from the day I picked it up from dealer.
I just been monitoring the tread wear, seems good so far.
As others have suggested, monitor tread wear and adjust pressures as needed for loads and towing activity.
Ford F-150 Tire pressure for bigger tires? Tire
Sigma1914
TJ
South Florida
2023 Rocky Ridge Ford F-150 XLT 5.0L V8 Coyote
I have 22in rims on 35in Toyo All Terrain. Every 5K miles I take it in to get a full synthetic oil change, tire balance, tire rotation, top off fluids and put all my tires at 40 psi.
Ford F-150 Tire pressure for bigger tires? DA992CFC-401B-4AA6-97DD-3CC2EFD5E6C2
timnohio
timnohio
Tim
2024 Ford F150
Sharp truck!
lrb_35128
Larry
San Antonio Metro Area
2024 F-150 King Ranch
Nitto says the 275/60R20 Nomads should be at 40-50psi. Thus, I've (currently) got them at 42psi.
Cooter
Butch
Maryland
US Government
Nice truck! Very nice indeed!
Shane150
Shane
Ontario, Canada
23 F150 Platinum PowerBoost
Very nice truck! Are those caliper covers or painted ones?
Graygoose2021
Oklahoma
Sales
Keep mine about 35-38psi.
Ford F-150 Tire pressure for bigger tires? 20231007_163101_resized_1
