- First Name
- Bruce
- Joined
- Jun 19, 2021
- Threads
- 5
- Messages
- 11,560
- Reaction score
- 22,964
- Location
- Coastal Texas
- Vehicles
- 2022 F150 KingRanch Powerboost
He's mastered the OBDLink App!
@Snakebitten what manual are you pulling that documentation from and where can I get it?Engine Coolant Loop
OBDLink. See this thread.What app are you using here? I dont have a PB but a 5.0 stx and have tried and tried to see my trans temp using torque and obd fusion. I cannot find a pid formula to add the temp myself.
There are SAE PIDs that support turbine inlet temperatures but apparently not supported by Ford.@Snakebitten likes to go into the specifics of the various loops, perhaps he knows if there's any aux coolant pumps. There's one in the trans, haven't seen anything for engine's cooling side of things. The PB's batt / DCDC / motor inverter have their own low pressure coolant loop.
My mach-e has 4 coolant pumps on, all electric of course.
There is an aux coolant pump connected to the heater core AND the turbos! What info do you have on that snake? Item 13 in the diagramThe only electric engine coolant pump that I know of is in the HVAC loop.
I’ve never seen firm printed guidance from Ford about a payload threshold. I use tow/haul whenever I’m towing *anything* and whenever my payload is ~75% or more of rated payload. I base that on the logic that I want the altered shift and TCC lockup strategy in that mode, among other things.Looking for feedback on when to engage tow haul mode.
Anytime I’m towing I have it engaged. How about when hauling stuff in the bed. Do you engage it when you hit a percent of max payload, when you hit a round number on weight, truck drive feel?
Curious what the best practice is for enabling it for hauling. Thanks.
I've never seen anything in the Factory Service Manual related to engine coolant pumps other than the two referenced in my earlier post.There is an aux coolant pump connected to the heater core AND the turbos! What info do you have on that snake? Item 13 in the diagram
What is that picture of?That sounds reasonable but watching the real time temperatures in both modes I have not seen any meaningful differences. Transmission temps seem to stay in a very narrow band of 210F to 220F with any outside temperature towing my Airstream. Here is a screen shot at 95F outside air temperature crossing the divide near Grants, NM.
What app are you using to see transmission temperature, ? thanksThat sounds reasonable but watching the real time temperatures in both modes I have not seen any meaningful differences. Transmission temps seem to stay in a very narrow band of 210F to 220F with any outside temperature towing my Airstream. Here is a screen shot at 95F outside air temperature crossing the divide near Grants, NM.
I'd be cautious doing that - I have a feeling that having the drivetrain switch into electric only mode when hauling 7000 pounds is probably not good for it. I've forgotten to put it in Tow/Haul mode for brief periods when hauling our 5000 pound Airstream without incident, but I always intend to use Tow/Haul mode.I have found with flat terrain, no wind or tailwind, my PB seems to do very well towing a 7,100 Airstream trailer in Normal Mode with a slight increase in milage. With head winds and/or mountainous terrain, I go to Tow/Haul mode. Make sense?
