Steering Stabilizer on leveled trucks?
SALEEN961
Radnor, PA
2021 F150 XLT 302A
Automotive Technician
Thanks. I go to a reputable 4x4 shop and actually asked about the Gen 14 alignment specs when they aligned it a year ago. They said they have them loaded into their computer but I don't think they set the caster near that high. Makes sense. Feels like shopping cart wheels when you hit a big bump at 70 mph.
If they accidentally used 2020 F150 alignment specs, they have the caster set much lower, as seen below
Ford F-150 Steering Stabilizer on leveled trucks? 2020 F150 Alignment Specs
LT tires run different pressures than SL. LT tires can change characteristics at different pressures. 44-50psi on the front. 45-55 in the rear depending on payload / towing. They're harsher riding tires so inflate to maintain drivability and mileage (not to be confused with comfort, which LT on 1/2 tons pretty much does away with factory ride). Even powerboost owners with 6klb empty weights ditched LTs to get the comfort back. To get the looks while keeping comfort, run SL/XL tires unless your circumstances require LT. The 20s are 8lbs heavier than 18" wheels so it's easier to get away with LTs on 18s with a little more comfort as well.
Ford F-150 Steering Stabilizer on leveled trucks? 1695747519355
Ford F-150 Steering Stabilizer on leveled trucks? 1695747452052
NotMyName
John Doe
2021 Bronco First Edition, 2022 F150 Platinum Powerboost 4x4 CCD
There are no broken parts and I can't see anything bent or know a reason why they would be. Tires are E Rated, inflated to 40 psi. The front feels like the wheel gets yanked on a high speed bump. The back feels jumpy and unsettled (which I would say is normal-ish in any empty pickup truck) on all bumps.
If it’s not too late, you can get the Raptor 35” KO2s in p-metric (really 34.4”). Would require smaller 17 wheel. I have the 34.1” Recons in p-metric 275/65r20 116T (largest Recon made without going up to D or E)on stock wheels and no level. Rides like a dream and get great fuel mileage
