It's a lot more than a "computer download".I can't believe a $50 optional plow prep package can't be installed after the build. Is a f150 going to be totaled if it has a dash fire and the plow prep wiring harness can't be replaced. It's probably a computer download anyway. I've called the dealer and Ford Motor Company and can't get a answer. Any Ford persons know someone at Ford who can help me. Or anyone know what part numbers I need to add this function? This makes no sense.
I think you're better off going that route anyway.Well I decided to have installed a Snowdogg MDII. They offer a wiring harness for a 2021/22 1/2 ton light duty truck with LED lights and without the snow plow prep package. The toggle switches for the lights can be replaced with black rocker switches that will match my other switches and mount nearly out of sight on the lower left side of the dash. This will work out fine as I only maintain my own private drive. The active air dam will be removed and I just had a leveling kit installed. They also offer a back drag blade that will assist up by my garage doors. Getting installed shortly.
