siriusxm radio not connecting
JD&JD
Jim
Iowa
2015 f150 lariat super crew -2015 escape titanium - 2000 f150 club cab
retired industrial electrician - still farming
Any one else having problems with sirius radio not connecting?
Can get wfi streaming channels but not satellite channels. Have truck for three weeks with no luck after
talking to 12 xm reps.
Jim Bandy
James
2021 F150 Limited 4x4 Powerboost (Hybrid)
?, is your tuner giving you a no signal message?
  • Like
Reactions: LWP
JD&JD
Jim
Iowa
No satellite signal attempting to connect
JD&JD
Jim
Iowa
I'm beginning to believe so. Do's not xm streaming and xm satellite use the same receiver?
Dan M.
Dan
Ruskin, FL
2021 KR SQ 4X4 PB
Retired Army
Call XM and tell them to refresh. You might have to give them your radio ID.
KBKEITH
^^^^^ this
Hambone
Aaron
Idaho
2021 F150 XLT Sport, 2011 F150
Home Inspector
I have been having issues with mine but the error that i get is: "Hardware Problem". Sometimes the XM works, sometimes it does not. Haven't yet talked to the dealer or XM about the issue.
JD&JD
Jim
Iowa
I've done that 12 times over the last three weeks. Last three times was told that the supervisor will call back, so far no callback! Holidays??
Webster
Niagara Falls, Ontario
2021 Ford F150 Hybrid
Mine is doing the same thing. What did you do to correct it?
Hambone
Aaron
Idaho
Home Inspector
It ended up being connected to multiple other faults and was eventually corrected when they replaced the ACM I believe. My 3 month trial expired a while back so I haven't tried using it again.
LWP
NC
Ford F150
The dealer replaced the ACM and another module and my XM still freezes after I turn it off temporarily and back on. The service told me it was a problem with the Sync 3 software and they are working on it. I saw where Sync 1 and 2 had software issues and the was a class action suit. In '23 I read they are replacing Sync 3 with another software. Nothing is plugged to my USB ports or anything else. It's my belief that they have a software problem they don't know how to fix.
LWP
NC
Ford F150
Think it's a Sync 3 problem and not XM.
