Side to Side rake on 22' Powerboost
scott011422
Scott
I installed a 1.5" front leveling kit. While measuring what I actually got out of it I noticed there is a 1" rake side to side with the drivers side being taller. I didn't measure both sides before the level kit, So I don't know if it was always like this.
Is this 1" side to side tilt normal?
DNazzy’s2025
Georgia
2025 Ford F150 Lariat
Project Manager
So you’re saying that measurements after install shows the drivers side 1” higher than the passenger? How are you taking your measurements? Make sure you are not putting the tape measure on the ground. Measure from the center of your hub to the bottom of your fender. Also, should go without saying, but you need to ensure you are on as flat a surface as possible.
I installed a 2.5” leveling kit. The before showed the drivers side about 1/4” higher than passenger. The after measurements show the drivers still exactly 1/4” higher than passenger. I would say 1” difference from side to side is way too much. That’s out of spec from the majority. I want to say up to 1/4” or slightly more would be “acceptable”. But once you get to 1/2” or more, that’s considerable.
