22Platinum
Tsb is out . Go see your dealer for the update
What's the TSB number?
What is the tsb number?Tsb is out . Go see your dealer for the update
I have to assume it’s not the transmission, it’s in the engine. The reason I say this is, as you know as someone watches their truck pretty hard, when climbing a steady grade the Powerboost initially uses electric torque to assist. If the battery runs down, the turbos step in. Once the turbos get over 2-3 psi, the shudder starts. If you force it to downshift a gear or two, it’ll stop shuddering. The torque demand hasn’t changed, only the source of the torque. If it was in the trans, I think it’d shudder regardless.There are multiple potential causes for "shudder" on these trucks, so not everyone is experiencing the same exact scenario. However, I've now had 2 different Gen14 Powerboost trucks with the 10r80 transmission and neither experienced what I see reported on the threads.
That at least IMPLIES that your truck shouldn't be "shuddering" in the described scenario. Ford can say that they have a solution forthcoming, but that implies that it would be a software solution?
My own personal opinion is that there is a significant variance between these trucks. Or put another way, if there were 10 identical trucks on the dealership lot, you might be surprised at just how different one or two might behave compared to the others.
I don't know what the percentage of trucks it is that suffer considerable shudder, but I have a suspicion that some component is operating outside the intended parameters. A torque converter might be a good example, but only a guess.
Also interested in the TSB number…Tsb is out . Go see your dealer for the update
Will that number work for 3.5 ecoboostLook for 22-2224. To reprog pcm and all others powertrain modules if its a powerboost
You could be absolutely right in regards to why my truck(s) don't shudder. I do watch a few pids incessantly and I intentionally override the oem shift strategy. Simply put, I avoid extreme low RPM cruising. "Extreme" being subjective, of course. For me personally, extreme is when the knock sensors kick in and start pulling timing.I have to assume it’s not the transmission, it’s in the engine. The reason I say this is, as you know as someone watches their truck pretty hard, when climbing a steady grade the Powerboost initially uses electric torque to assist. If the battery runs down, the turbos step in. Once the turbos get over 2-3 psi, the shudder starts. If you force it to downshift a gear or two, it’ll stop shuddering. The torque demand hasn’t changed, only the source of the torque. If it was in the trans, I think it’d shudder regardless.
With that said - I think those who use less cruise control won’t notice it near as much, as the truck is much more eager to downshift when driving with your foot. My truck will build 10-15 lbs of boost in 10th on cruise control
I have had that TSB performed and it did not resolve the issue.Look for 22-2224. To reprog pcm and all others powertrain modules if its a powerboost
Did you ever get your Torque converter fixed? If so, did it fix the shudder?I just had this diagnosed as a bad torque converter,parts on order
Shameless super late update. Recently had my torque converter replaced, and my shudder is back within 300 miles. What the heck is going on? Any updates on yours?After getting a new torque converter,valve body,truck still shudders,very dissapointed with this truck.
