Shifting/popping drivers seat 2024?
Gref150
Sioux Falls, SD
2024 F150 Lariat, 1989 Mustang LX Convertible
Anyone else having the looseness/popping when turning in the seat bottom on a 2024? I have had it on my Lariat the past several months now, can feel slight shift side to side if turning hard enough and popping in center of cushion when going over larger bumps. Seems it's been a problem since 2015, has anyone successfully had their dealer warranty the seat or are there any service bulletins that cover 2024?
mwf5888
Michael
Fort Wayne, IN
Instructional Designer
I had my driver's seat frame replaced because the support weld broke on the lower back, causing the seat cover's plastic snaps to come off on the front and console side. They only stated (not in writing) that the support bars on the back and bottom of the seat have had failures around the country.
I had to return because the seat cover's plastic snap came off on the front and made it move a little.
Replaced under warranty.
rugedraw
Javier
Miami
Auto Sales
My 2021 has done this since I bought it almost 4 years ago. Dealer can never replicate the problem. I'm just used to it by now.
L33der
PA
25 Explorer ST, 24 F150 LARIAT FX4 BAP, 20 Transit XLT, 17 Explorer Sport
IT, Dog Musher
My 2024 LARIAT is doing the same thing.
Gref150
Gref150
Sioux Falls, SD
Update.....I saw one guy post somewhere about the popping in the middle of the bottom seat cushion and he solved it by slightly raising the seat up. I did this and it fixed my popping, though the side to side shifting continues. It seems if your seat is bottomed out it can cause all kinds of looseness and popping, raising it up even a half inch puts some motor tension on it. Hope this helps someone.
