Rubbing/grinding noise when at low speed
ajpettry33
AJ
Iowa
2021 F150 3.5
I just noticed today that when I'm approaching a stop sign, driving straight, and NOT pushing the brake my truck is making a rubbing or grinding noise and you can slightly feel it as well. I checked to see if anything is rubbing on the tires/etc and cannot see any sort of piece rubbing. Any idea?
Gros Ventre
Western Wyoming
Don't know what it is... But don't be fooled by it's going away at higher speed. Like an out of balance tire that vibrates at low speed & seems to go away at higher speed, it's still vibrating and damaging things.
Kanuck
Winnipeg, Manitoba
Retired Electrician
Sounds like either a bearing or brake caliber not totally releasing. front? back? side? Does it go away when you step on the brakes?
PB2021
Rob
2021 F150 Lariat Powerboost
Max tow axle equipped truck? Check your centre bolts on rear axles
pavementends
Idaho
Enginerd
You did say you can feel it, so not sure if this applies but there is a thin metal round "dust guard" on the inboard side of the entire brake rotor that is easily bent out of shape that can gently rub against the brake rotor until you gently bend it back. This became an issue for me recently after getting new tires installed and tire shop bent both front dust guards enough to rub the rotors. Easy fix, but might require removing the wheel to get to the whole thing. Just an FYI.
LouDog
Sean
Grand Junction CO
21’ Lariat Powerboost
I’ve got the same issue. 21’ lariat PB. Not always present and shows up loud at around 5mph but intermittently. Wish I knew the issue!
ajpettry33
AJ
Iowa
2021 F150 3.5
Yeah sounds like my issue. I didnt notice it today after putting about 75 miles on yesterday ?‍♂
Chad_Cole_311
Chad
Castle Rock, CO
2021 F-150 3.5L Platinum Powerboost 7.2kw
Automotive Performance
Did you ever figure this out? Mine is doing this exact thing.
Ford Motor Company
Official Ford Account
Ford
Dearborn
Hi, Chad! I'd be happy to assist you regarding this grinding concern should you have any concerns. Please send over a direct message with your VIN and dealer name/location, and I'll get right on it. To send a direct message, just click on our username and select "Send Direct Message".
Bricklayer14
Dean
Akron, Oh
2023 F150 Tremor
Grinding/Rubbing Noise at Low Speed + Poor Gas Mileage (15.5 MPG on Highway)
Hey everyone,
I’ve been experiencing an issue with my 2023 F-150 3.5L EcoBoost (Tremor) where I hear a grinding or rubbing noise when approaching a stop sign while driving straight without pressing the brakes. I can also slightly feel the vibration.
Additionally, my gas mileage has been unusually lowonly 15.5 MPG, even though I drive about 70% highway miles. This seems way lower than what others report for similar driving conditions.
Has anyone else had this combination of issues? Could they be related?
Appreciate any insights!
Thanks!
F-1Fiddy
Jordan
British Columbia, Canada 🇨🇦
2023 F150 Tremor 402a iconic silver
electrician
Any resolution to this issue. My 2023 tremor goes in tomorrow for this issue and wanted to have an idea on what they could check.
