Request VIN Lookup Thread
Seanrblock
Sean
2012 F150 Powerboost Lariat
Operations Manager
Like this In the attached photo? I have never modified any as built module manually. It won't allow me to do lowercase "x" only upper case. Then clock "write" below it and refresh? Anything else to update? Thank you so much for jumping in to help! Waiting for your reply so I don't jack something up.
Also is it a ZERO or an "O" in XEX0? Assuming a zero but making sure.
x is what is already listed...only change non x locations.
Change to this ...
706-01-01 8E50 A219 AE--
"--" is a check digit that the software creates. Don't worry about it..
Got it. So I don't worry about the last two digits just leave them? Or put the -- in and it will generate digits after I write? Sorry first time.
Kanuck
Winnipeg, Manitoba
Retired Electrician
Leave it blank....0 is zero
They only use 1,2,3,4,5,6,7,8,9,0,A,B,C,D,E,F in the codes
Seanrblock
Sean
Operations Manager
Ok updated, ignore my last post. It changed the last two to "56". All good now? Anything else that could impact Bluecruise or OTA updates I can fix? Sorry, now I get how this works.
Ford F-150 Request VIN Lookup Thread 20250622_130848
Looks good. Is your fdrs license still active?
@Seanrblock The config for your cameras is all jacked up, too. Makes these changes in the IPMA:
706-02-02
xxxF CExx xx--
If your FDRS license is still active, click the IPMA here, and download and run the "read configuration data" routine.
Ford F-150 Request VIN Lookup Thread 1750613185825-l
Seanrblock
Sean
Operations Manager
706-02-02
xxxF CExx xx--
Will do. So I switched from regular to tow mirrors and ran the 360 cam program in Forscan. Wonder if that did it, regardless will update. As I replied before, FDRS expired but I can review if there is something big that will fix OTA or BlueCruise.
It expired last night, but happy to pay if there are issues that need to be addressed.
What I mentioned above would only update the FORScan changes you made up to the server. I very much doubt that will bring BC up in Fordpass for you. You can try, but it will most likely be a waste of $50. You are going to have to call Ford to see what is going on with that.
As of right now, you have all the right software and config for BC to work.
@Seanrblock Actually, take the truck on a road test and try BC to see if it works. Remember that with the IPMA software you have now, you will need to have the seatbelt plugged in, or lane centering/BC will not engage.
Seanrblock
Sean
Operations Manager
If I don't have it available in Ford Pass or a subscription, will I get some sort of alert even if I don't have it anywhere with an older 21 that it's not free anymore? I drove an Expedition with it, and it would tell me it was available on most roads when I turned on cruise with lane assist (as you said) I drive with it all the time in my truck, but I assumed the alert was because it had the subscription. Thanks so much for all of your help! I just wish I could confirm it's ready to go somehow.
Seanrblock
Sean
Operations Manager
Fantastic, thank you!
I can tell you that you don't need an active subscription for it to work. The only way to know is by road testing it. I can tell you the config is now correct and it was not before, so there was no way it could engage with the config you had prior to today.
Seanrblock
Sean
Operations Manager
Ok we
I can tell you that you don't need an active subscription for it to work. The only way to know is by road testing it. I can tell you the config is now correct and it was not before, so there was no way for it could engage.
Ok awesome, thank you! I will grab a road that has it and report back if I get that it's available.
It w
It works!!! Thank you so much for all of your help. Why is it free for me? It's a 21 with no subscription ?. I'm confused how it works without paying.
That's pretty cool.
So in FordPass, it doesn't show as active under connected services?
