Heyben
Good Morning and Merry Christmas Guys, could someone please check 1FTFW1EDXMFB04914 for FDRS updates? Wondering if it's time to purchase another 2 day license to update anything. Thanks in advance!
I can check FDRS for you later when I get home, but based on your OTA history, 6.3.0 was the last OTA you got. I would wait a bit before getting another license. It is believed we will be getting a better version of Bluecruise early next year. Your truck being a Limited would benefit from those updates when they are released.Good Morning and Merry Christmas Guys, could someone please check 1FTFW1EDXMFB04914 for FDRS updates? Wondering if it's time to purchase another 2 day license to update anything. Thanks in advance!
Thanks Rugedraw, I appreciate your response. I'll wait until next year per your suggestion.I can check FDRS for you later when I get home, but based on your OTA history, 6.3.0 was the last OTA you got. I would wait a bit before getting another license. It is believed we will be getting a better version of Bluecruise early next year. Your truck being a Limited would benefit from those updates when they are released.
As of December 12th, your truck is no longer reporting low battery codes. You have not been sent any updates since November 21st. That healthy battery you have now should help ensure future updates install successfully.Could I get another check? 1FTFW1E50MFA34297. Second dealership confirmed there was a battery/draw issue immediately and replaced the battery. First dealership "couldn't find any issue". I still feel like it has some odd quirks to it. I swear seat doesn't always go in correct position, Apple Carplay seems erratic, and a few other things. It runs better and doesn't stall out after auto stop with a variety of messages any longer. That is a positive.
I feel like sometimes when I check its connectivity in front of the house the wifi is off? Should I have to connect this to my network when pulling in or should it be automatic?As of December 12th, your truck is no longer reporting low battery codes. You have not been sent any updates since November 21st. That healthy battery you have now should help ensure future updates install successfully.
These are the codes it recorded that day:Would someone with PTS/Oasis be able to look at the historical DTCs for the PCM in my truck. Had to clear codes, KAM, and adaptive tables to get truck running reliably again. Looking for the 2 codes and their descriptions for engine disconnect clutch stuck open / engagement fault. Believe one of the codes was P2884.
1FTFW1ED0MFB66211
‘21 PB
I am not sure because I have wifi off. No OTA released for any of these connected Ford vehicles requires wifi to download.I feel like sometimes when I check its connectivity in front of the house the wifi is off? Should I have to connect this to my network when pulling in or should it be automatic?
Yes, but nothing you need to be concerned about. All vehicles I check have some code being recorded.Is it reporting any other codes outside of the battery codes?
Thank you sir! Much appreciated.These are the codes it recorded that day:
Last OTA you got was 4.3.5 mid-November. Your truck is ready for the 6.x.x updates. As to why you haven't gotten any? Your guess is as good as anybody's. Ford's OTA process is unpredictable like that. If you have gotten this far, there is nothing wrong with your truck. The problem is Ford's OTA process.1FTEW1EP6MFC56470
software still at 4.3 something…
2022 f150 lariat, connected to WiFi and new battery… not sure why no updates anymore
Thank you for your time!Last OTA you got was 4.3.5 mid-November. Your truck is ready for the 6.x.x updates. As to why you haven't gotten any? Your guess is as good as anybody's. Ford's OTA process is unpredictable like that. If you have gotten this far, there is nothing wrong with your truck. The problem is Ford's OTA process.
