Request VIN Lookup Thread
Californiacarver
Nor Cal
You were sent 3.5.3 on 1/24 and your truck has been struggling to download the files since then. Based on your current sync version, I believe you are up to date with the older updates 2021 trucks were due. Good luck!
Guess I still need to wait for the latest update to get the full screen. Can I ask what you mean by struggling. Checked my WIFI signal and its strong. Anything else I could do?
Also is there a way to check what version by using forscan?
Rugedraw could you check my VIN again please? 1FTFW1ED3MFB06312
Job 1 2021. Got 2.7.3 in October, but nothing since. Wondering if anything has even tried in the last couple of months. I'm thinking maybe I'm having battery issues block me now and I don't realize it...
Thanks!
Yes, I see you got 2.7.3 (which is an IPC update) in early December, and it says it went through successfully. No OTAs have been sent to your truck since then. I checked your DTCs and your truck has not reported any low battery codes. You are behind in updates and Ford doesn't roll out those updates very often, but your Sync version is high enough to where you are past the hump where these trucks get stuck, so that is good.
1FTEW1CP6MKF12990 thanks again for your time.
Nothing since you got some Bluecruise map updates in December.
It has nothing to do with your connection. It's the OTA process itself. It seems GWM didn't like one or two of the files sent to your truck, because it seems to have downloaded all but two of the files it needed the same day you got the update. Since then, your truck has tried to download the files countless times to no avail. There is nothing you can do to help.
pavementends
Idaho
Enginerd
I was also sent 3.5.3 on 1/24 and it's successfully downloaded multiple files but hung up on others, just like you. So today is day #14 in limbo for us. There are many others sent the update in late January and I shared everything I've tried in the following thread if you're curious... https://www.f150gen14.com/forum/threads/truck-sent-but-wont-download-ota-powerup-3-5-3.15053/
Texas2022XLT
2022 F150 XLT 302A
Can someone check my VIN please? Had it at the dealership and wanted to see what they all updated. They stated the APIM but I see I have a later version of Sync now too.
1FTFW1E82NKE63556
ESG406
Ed
Union City PA
21F150 Hyb, 15ExpEL 2 '06 Esc Hyb 99&01elect Rngrs
Hello Javier,
I can't tell if an update is going to go through or not. I can only see it if you have it, and if it ultimately went through or failed.
I called Ford today, Feb 6. They said it was downloading but it was not going through because my gas tank was not full-was 60% full. Have you ever heard of that? I put in 10 gallons and gauge reads full/516 miles to empty. Can you see status of current update? 1FTFW1ED5MFB77138.
Thank you.
1FTFW1E82NKE63556
I'll have to check tomorrow. I can't see FDRS history from the app.
Hello Javier,
Thank you.
Lmfaooooo! Did they really say that?!?!?
Your update is trying to download the files like everyone else's. I don't know why it's not downloading, but I can tell with with 100% that's not the reason, and it's a damn shame that was the excuse they gave you.
ESG406
Ed
Union City PA
They/she really said that As soon as I hear from you I plan to call Ford. thanks, Ed
1FTFW1E82NKE63556
I don't have FDRS to see what modules you have still pending updating, but they updated your APIM and nothing else. You were sent 3.5.3.2 on 1/26 and it failed the same day. On 2/6, I see they updated your APIM, but nothing else. That would be the equivalent of the 3.5.3.2 OTA. I don't they updated the TCU which would bring to to 3.5.4, but the updated they gave is the one that actually gives you something new and tangible on your truck.
I responded to you already. That comment about tomorrow was for the member I quoted above.
Don't bother calling them unless you enjoy wasting your time. They cannot do anything to help you get the update. You're better off asking a ouija board why your update is going through than any of the fluffers on the OTA hotline.
Texas2022XLT
2022 F150 XLT 302A
Thank you, it’s back at the dealership today still working on the compass issue.
jordandev
Jordan
Could I get an OTA check? - 1FTFW1E84MKE02174
Thanks!
Thanks!
You were sent 3.5.3 back on 1/26 and it is in limbo trying to download the needed files. Nothing you can do to help the process. Good luck.
Fordphanatic
Boothwyn
2021 Platinum F150
Union Carpenter
After 2 days at the dealership and multiple updates I’m still on the same outdated system so where do I go from here
https://www.f150gen14.com/forum/threads/ecu-module-programming-guide-using-fdrs.8249/
I would start here. When the dealor fails you this is your only hope. It's not cheap but you CAN do it.
