Request VIN Lookup Thread
Fone5o
Ontario, Canada
2021 F-150 XLT 5.0L Lead Foot Sport
Hello, could I please get my VIN checked. I received a new APIM module in June, last update says July 23rd.
1FTFW1E53MKD71103
BlindSnapper
Stu
UTAH
21 F-150 XLT
Can I get a vin check as well please?
1FTFW1E81MFB62350
edubbz
Can someone check my VIN as well? Thanks!
1FTFW1E83MFB87024
Jayt
NC
2021 F150 Lariat
1FTEW1EP0MFA95307
Last update I’m showing was on June 15, 2022 and it was 2.7.1. Thank you.
rugedraw
Javier
Miami
Auto Sales
1FTFW1E53MKD71103
You've had update 2.8.1 sitting in your queue since the end of October. It has tried to install several times but failed due to low battery voltage. This update is notorious for this. You need to connect your truck to a minimum 10amp battery charger, go into your settings, check for updates and manually kick off the update. This will require you vehicle to be parked and locked for maybe 1.5-2 hours. Make sure you set your headlights to off (not auto) and set your parking brake on. You will be able to see a progress bar on your screen as it installs. Do NOT open or unlock the truck during the install process. I wouldn't even walk close to it with the key jic.
1FTFW1E81MFB62350
No OTA history in the past 60 days. You have a newer version on Sync on your truck. I see no indications your truck is stuck not getting updates.
Can I get a vin lookup for software/module updates thanks! 1FTFW1E58NKD87010
Nothing OTA in the past 60 days. You have a 2022, so they only thing you'd be missing is 3.5.2 and now recently them seem to have started rolling out 3.5.3 and 3.5.4 again. I don't have FDRS to check pending module updates.
1FTEW1EP0MFA95307
Same as above: No OTA history in the past 60 days. You have a newer version on Sync on your truck. I see no indications your truck is stuck not getting updates
Francis Bellows
Francis
McCordsville IN
2022 Ford F150 xlt
Hey guys, I've been trying to get my truck all sorted out with updates and have started keeping it on a charger since my battery was only 60-70% even after changes forscan settings. Could someone lookup my vin please and let me know if it shows its tried. Thanks! 1ftfw1e89nfa64670
Fone5o
Ontario, Canada
Thanks a lot rugedraw I’ll try that. However when I do go to setting it says my system is up to date. Thanks for the help!
rugedraw
Javier
Miami
Auto Sales
That's weird. Files were downloaded and just sitting in your queue since 10/18. Your truck tried to install the update a few times between then and 10/23, and are just sitting there waiting since 10/24. Never seen an update last that long without timing out.
Ford F-150 Request VIN Lookup Thread Picture2
Fone5o
Ontario, Canada
I appreciate the info man! Maybe something the dealer will have to check out.
GraffiX
Alex
NJ
2022 F-150 Platinum PB
Can you please check my VIN 1FTFW1EDXNFB47439.
It seemed like I had an update try to go through in Oct but I don't know if it completed or didn't take.
Thanks in advance.
rugedraw
Javier
Miami
Auto Sales
Thanks in advance.
No OTA history in the past 60 days, so I can't see what you got in October. You having a 2022, the only thing it could have been is 3.5.2 or a bluecruise map update.
Blue2022
2022 F150 Platinum, 2021 Excape
Could you check my vin please? 1FTFW1ED3NFA10195
Truck was picked up at the dealership 1 year ago yesterday.
Davee123
Minnesota
2021 F150 XLT 3.5 EB
Appreciate everyone for all the useful info on this thread. I just recently purchased an f150 and am wondering about the update situation with the truck for the APIM. VIN is 1FTFW1E85MFC49636. Thanks to everyone.
lemonjive
Reid
Mill Creek, WA
2021 F-150 Powerboost
I know I am a few ota's behind. How about mine, 1ftfw1ed6mfa94642
