Refrigerant Oil or Coolant Leak
eamatherne
Louisiana
2021 F-150 Limited POWERBOOST Hybrid 4x4
I have a coolant leak. I had a big yellow pool on my garage floor. It looks like the part where it is leaking has something to do with the Electric Battery cooling system. Spent almost 45 minutes with Ford parts guy trying to figure it out. I went to service department, showed them the pictures and they have no idea. It looks like the leak is where the lines attach to some kind of valve. I tried tightening up the nut where the two lines manifold to the part. It still has a slight leak. It looks like the tubing didn’t seat correctly. This will be a long process as you can’t even get a service department to look at it without leaving it for a few days. Add that to the fact a part number can’t even be determined and you have a nightmare!
Ford F-150 Refrigerant Oil or Coolant Leak C4020426-3D42-433A-A675-4767D6DF25FE
Ford F-150 Refrigerant Oil or Coolant Leak 4C9DF946-6C5A-455F-AE0F-A839B0659819
Ford F-150 Refrigerant Oil or Coolant Leak 5A63EF9C-FAE9-4EF9-8A5F-1E9EC3FDBB08
Ford F-150 Refrigerant Oil or Coolant Leak D75782D4-E41D-4B77-9000-9B47ADF3C054
Ford F-150 Refrigerant Oil or Coolant Leak coolant leak
Bravo36
Kevin
Dallas, Tx.
2021 F-150 King Ranch FX 4
Retired Fed LEO, Current Federal Contractor
What the hell is that?
Knickell
Mazda Protege, Ford F-150
Yea, I know what you’re saying. You’ll have to down the truck for at least a few days.
Lippy
CA
2021 F-150 Powerboost
Don't sweat it. Bring it in.
imnuts
Dirty Jerz
'21 502A Powerboost 4×4
Facilities Engineer
There's probably an o-ring in there that isn't seated properly. Tightening it down will help, but if there is something else in there sealing it, it'll likely only get worse with time.
maxinike
Stephane
ontario
f150 powerboost, ranger 2020 and lawn tractor
the image you refer is the control valve for the refrigerent to the coolant cooler for the high voltage battery.
the seal you show seal the refrigerent. if you feel that is coolant leak then is not coming from there. maybe the black rubber hose beside are for coolant. dont tight the bolt too much that will cause refrigerent leak. make sure its not oily as it look like refrigerent pag oil. the coolant in this cooler is for the electric powertrain. look for low coolant level in the small degas bottle and that will confirm its leaking electric powertrain coolant.
Soldado
Juan
Pennsylvania
2021 Ford F150 Platinum Powerboost
Please let us know what you find out. I looked under my Powerboost yesterday and may have something similar going on. I'm keeping an eye on it for now.
Juan
Swegner99
Arizona
2021 F150 XLT, 2017 Expedition EL
Ford F-150 Refrigerant Oil or Coolant Leak 1618590430367
The nuts you are showing to have tightened are A/C lines, looks like refrigerant is run to that cooler which cools antifreeze for the battery cooling system. Definitely new technology for the PB.
Do you have a picture of the puddle on the ground? Are you sure its actually coolant leaking?
Tecdiver
Dana
Michigan, USA
2021 F150 Lariat PB
Corporate shill
Moral of this story - ensure you have complimentary rental coverage through your dealer if you're like many who have a PB on order but haven't yet closed the deal!
eamatherne
eamatherne
Louisiana
Ford F-150 Refrigerant Oil or Coolant Leak CAC711D8-1B40-44CC-A098-6A1EFDC6B42C
eamatherne
eamatherne
Louisiana
Its not refrigerant. When I loosened the nut, the coolant came out. It wasnt like a high pressure refrigerant spewing out. The hoses that attached to the device are going up to the coolant reservoir. I think that it's and O-ring that is damaged possibly?
maxinike
Stephane
ontario
the new type of oil in refrigerent can be confused with coolant because of dye added in oil. it is possible to make oil leak if you loose the nuts just enough before the gas start leak. there is no reson to have coolant in these lines.
eamatherne
eamatherne
Louisiana
You might be right. I think it could be refrigerant oil. It is so hard to trace the lines to see where it goes. This is going to be a nightmare to get fixed. I just texted my dealer. The first available appointment is May 19th. Also noticed a bunch more rust on the front end frame by the wheels. Ugh!@1!@
eamatherne
eamatherne
Louisiana
Ford F-150 Refrigerant Oil or Coolant Leak 414628F4-5387-4769-AD69-3D8B3E981D9E
