amschind
That is awesome. It makes it more curious why they aren't coating piston faces (or are they?). The one part of the Carnot equation that we can adjust is the hot temperature; Brayton turbine engines have benefitted quite a bit from ceramics pushing temperatures up, but we haven't seen the same advances for piston engines. I'm thrilled to see evidence that it is penetrating into the mass market.The 5.0 uses a ceramic hybrid with its PTWA cylinder liners. It’s been quite successful beyond the initial teething issues figuring out the correct ring to control the oil that better sticks to the cylinder bore. The cylinder liners are Nanocrystalline Iron with FeO (ceramic) hybrid. The engineers that designed the 3rd and 4th gen 5.0L V8 stated in all the durability testing the 5.0 still has the cross hashing at the 200,000 mile mark, and that cylinder bore wear was non-existent. They also state you do not need to hone the bores when you rebuild these motors, the coating is that hard. New rings and pistons on rebuild, but no work to the bores. Ford does the same practice for the remans on these engines, but I recall reading that Ford can re-do the process on remans in the event it’s required (apparently not often). The one caveat is that you need a new block if you have a catastrophic failure that cracks the coating.
