PWM setting in BCM module
sup3rrac3r
Tim
Germany
Ford Mondeo MK5 wagon
Hello,
I read a lot about the brightness control of DRL LED lights by changing the duty cycle of the pulse width modulation.
As far as I know, combined LED stop/parking lights also use this technique.
Until now, I did not find any address blocks in the bcm module that point to a setting that can influence the tail lights brightness (while it's possible with other manufacturers, VW as an example).
Has anyone ever figured out where to look for such a setting or can give a hint?
My car is a Europen Ford Mondeo (similar to the 2gen Fusion), but I'm more for the principle than for a detailed instruction on how to achieve this mod.
Thanks
Tim
KyleSimmons
TN
2024 F150
Photographer
Hello,
Thanks
Tim
Ii know this is old but did you ever find out how to modify the PWM/Duty Cycle within Forscan perhaps
