Powerboost extended storage - battery tender?
macsinbragg
bragg Creek Alberta
2016 f 150
I will be heading down south and was planning on taking the truck and trailer down to Arizona, however the border with the US is still closed to land traffic so we are going to fly down. My question is what do I need to do as I wont be driving the truck for several months? Do I need to put a battery tender on it? Anything else I should be doing?
Thanks,
Scotty
crvz
chris
third coast
2021 F150 Tremor (order), 2019 M2
I work in the lithium ion battery field (space flight use), and in general a lithium battery without a load should hold charge for months (and longer) without a tender. But… I haven’t looked at any kind of schematics for the powerboost application. I’d be surprised if there are active loads on the lithium battery when parked, and I suspect you can leave alone. Further, it’s not a 12V battery (A quick google search shows it can be up to 450V?), so I don’t know what tender you might even use. What does Ford say about long-term storage?
A tender on the 12V battery for the ICE electrical system would be smart, but it likely won’t do anything for the powerboost battery.
Lippy
CA
2021 F-150 Powerboost
I would use a CTEK.
Jus Cruisin
Tim
Metro Detroit
Very retired
I have 2 Battery Tenders that I have used for years on various cars and trucks. I for sure would use one on the Powerboost if it's going to sit for as little as 2 weeks. I haven't had that need, yet. I have already used it on my 2021 Explorer as it doesn't get driven much.
McGuyver
Ed
Tundra, Grand National
Here’s a crazy idea. Plug your battery tender into the powerpro outlet and let the truck start itself up as needed to charge the lithium battery. Parked in a secure area outdoors of course.
FaaWrenchBndr
Denver, IN
‘24 XLT Powerboost
I have it connected directly to the battery, positive terminal and the terminal for the negative side BMS. I have the connection lead running out towards the top of the grill. I can reach in and pull it out to plug it in and when unplugged it gets tucked back behind the grill.
