scott011422
This is about the "Eco Coach" on the IPC. When you are coasting or braking this going into a green "Charging" bar graph. If you brake hard enough the word "Charging" turns to white and the portion of the bar that moves out of the green zone also turns white. I've always been told that this white area is when the mechanical brake is starting to be applied because you are requesting more braking than the regen can provide. Makes total sense.
Recently I've developed an odd click on the front drivers brake every time the mechanical brake is engaged. Sounds like a solenoid hitting sheetmetal. So now I have an audible feedback everything the mechanical brakes are used., And it doesn't follow that charging graph AT ALL. I've had whole braking events that didn't go much past halve of the green charging zone and had the mechanical brake engage. I've almost never had the brakes engage when crossing into the white zone. I've had brake events well into the white zone that didn't engage the mechanical brakes.
So then what exactly is the white zone? If it is displaying the regen capacity, What is it doing with the extra power its generating? If it cant store it, and isn't using the mechanical brakes, where is the power going? Is there a heating element somewhere?
Even if it was break efficiency, again, where is all the extra power going? To electrically brake you need a load, They need to do SOMETHING with the power.
