Tosh
- Joined
- Apr 2, 2021
- Threads
- 1
- Messages
- 256
- Reaction score
- 224
- Location
- Willamette Valley, Oregon
- Vehicles
- 2021 F150 Lariat Powerboost, 2024 Mach E Rally
- Occupation
- Re-Tired Bicycle Mechanic
I mean "inefficient" compared to charging from the grid.
Worth noting that you won't be able to pull 30 amps from the ProPower continuously, and the portable charger you get with the Mach-E is designed to draw 32 amps @ 240 volts.
Here's a video - about 5 minutes in they demonstrate what happens
https://www.youtube.com/watch?v=ePW1uLsnh7s
I typically charge from 30% to 70% in 3.25 hrs @ 48amps/240volts. Assuming I had an ev charger set to draw 24 amps, I would expect to wait 6.5 hrs for the same charge from my Powerboost. I would also expect to use about 6 gallons of gas, for the cost of about $25. The cost for that same charge from my grid would be about $6. The cost for that charge from my solar array is $0.
Nevertheless, I say do it. I'm going to be looking for a portable EV charger that will draw 24 amps @ 240, and the proper adapter to connect to the ProPower L14-30 outlet for myself.
