That's for heating the engine block and has nothing to do with the HV aux loop. A battery runningI have seen and put my hand on the heat exchanger for the battery down on the passenger side by the resonator. It has a switch to circulate the battery cooling circuit in an exchanger that sits wrapped around the exhaust. As well, C rate is just the internal resistance of the battery dissipating heat with high amperage flow either charging or discharging. Extreme temps on both sides of temp spectrum have to be controlled to avoid thermal runaway and/or damage under ether extreme.
~25c doesn't need a heater -- it is a heater.
