Power tailgate on 2021
2014fx4
James
Humboldt, sk
2014 f150 fx4, 2020 hyundai palisade
Hello, i currently have a 2021 f150 lariat with a non power tailgate and no step. It has a camera and i can open it with a push of a button. The tailgate got damaged beyond repair and i found a tailgate close to me but it has power, tailgate step, and work surface. Would i be able to make this tailgate work on my truck? I dont care if the power feature works, i just want to know if it will still open and close properly, im not sure if the latches are different from my current tailgate to this one. Thanks.
Yves
Yves
Gatineau, Quebec, Canada
F-150 2021 Powerboost XLT 302A 360 Camera 7.2KW
The tailgate that you found is coming from which year of F-150
2014fx4
James
Humboldt, sk
Seller claims its off a 2021
FORDTEXAS
2022 F150 LARIAT
hmm good question.. idk if the motor on the powered tailgate models are inside the tailgate or the actual truck
Kanuck
Winnipeg, Manitoba
Retired Electrician
Motor is in the tailgate. I read on here that the tailgates are different on the inside due to the power unit. As for interchangeable - sorry, I don't know. @Jesse-Infotainment would be the best person to PM about it. He might know, but if not, he would know whom to message.
FORDTEXAS
2022 F150 LARIAT
if motor is in inside the tailgate then i’m under the impression OP should be able to install the said tailgate.
Kanuck
Winnipeg, Manitoba
Retired Electrician
I am thinking that the pivot points (hinges) maybe different to allow the motor to move the tailgate up or down.
Mash150
Dale
North of the 49th
21 King Ranch, 157, SQ , PB
Well there is this difference on the power gate that is not there on the non power tailgates as far as I know. I’m not sure what the purpose of the screw serves but it might be some type of limiter function.
Ford F-150 Power tailgate on 2021 IMG_3146
JohngaltinOC
Orange County ca
2021 F150 lariat EB
Finance
From my understanding that screw is simply there to prevent or hinder removal of the tail gate. I replaced mine with the special Torx head bolt (forget the name) that has the little pin, hoping any thieves won't have the right tools in their pocket...
Kanuck
Winnipeg, Manitoba
Retired Electrician
Without seeing a power tailgate and the motor being in the tailgate - I suspect the tailgate drive rotates the shaft coming out of the tailgate. The shaft would have to be solid on the side of the box. It can't turn otherwise the tailgate would not move.
Torx Security Bolt
JJSnell
JJSnell
CdA, ID
2022 F150 Platinum FX4 PB
Any Canucks near James that can do a quick test, swaparoo?
I would be VERY surpised if Ford had different locations for hinges and latches. If they do, that would be another failure on Fords part. Would take different molds and casts and support plates in both the bed and tailgate. But Ive seen dumber....
What would it take to get the gate to work? Many of these wiring harnesses have open plugs at the end. Maybe its just getting the final harness and switch inside the truck?
Yves
Yves
I agree the hinges are probably all at the same place. The ones that have motorized tailgate, are you able to open it manually?
Kanuck
Winnipeg, Manitoba
Retired Electrician
I think they are manual open ( Dampener) but power close.
JJSnell
JJSnell
CdA, ID
2022 PB Plat
Well Ill be... Never knew that. Went out there and tried to get the thing to power close, button is in awkward place.. So I lifted the tailgate up a bit then let go and it closed by itself. So it works from key fob and 'manual assist".
2014fx4
James
Humboldt, sk
Im guessing the actuators to unlatched the tailgate are the same on both tailgates. Have to check the hinge where the motor is to see if they can be Swapped out. I have no intensions of using the motor anyways.
