Power Running Boards Out
DFMAGuy
DFMAGuy
New York
2023 F150 Lariat Powerboost
Design Engineer
I understand in the NE it is advised to leave my 23 PB Lariat Running Boards in the out position (to prevent salt corrosion and drag on the hinges / actuators) - I see the "out" toggle in the Features / Power Running Boards but they pull back in when the speed sensors pick up more than 3 MPH ... How to I deploy them in the out position until Spring ? TIA
Smokewagun
Bob
N. Illinois
2023 Ford F-150 Lariat Lightning
And, this is a rumor. Have had four or more sets over the years in the midwest. Nye an issue. Just maintain them.
dzacco
Denver, CO
2021 F150 Limited Powerboost
What maintenance is required? I haven't looked at them, are there pivot points to lubricate? Do you use dry lube of some sort?
RcFlyer330
Cameron
2022 F150 Limited Powerboost
When you wash the vehicle or every once in a wile use a garden hose to wash the salt off the hinges. you can lubricate them and it will be similar to this video below.
dzacco
Denver, CO
Thank You,
Mine make a loud grunting noise so this might help.
