oneinch
- Joined
- Apr 17, 2022
- Threads
- 36
- Messages
- 629
- Reaction score
- 565
- Location
- Philly area
- Vehicles
- 2022 F150 Powerboost, 2022 Maverick Lariat Lux
My only 12 volt outlet is in the rear seat area of the center console. I want to keep a device plugged into it. I want this device to shut off when I shut the truck off. My outlet stays hot after turning off the truck. I kept checking it to determine how long it stayed hot. It finally shut off around the 30 minute mark. No bueno for my needs.
With FORScan can I change this? In the BCM module, line 726-57-01 xxxx **xx xx-- is Power_Point_Timeout_Cfg (PPTC). There are two options shown in @Livnitup 's spreadsheet: 00=PPTC DISABLE and 01=PPTC ENABLE. My configuration is PPTC ENABLE.
My questions are: 1) Is the Power_Point referenced my 12 volt outlet?, 2) If yes, is the Power_Point only the 12 volt outlet?, 3) Will changing this setting to disable force my single 12 volt outlet to shut off when I shut the truck off?, 4) If left enabled, can I change the timeout time to the number of seconds of my choosing?
Thanks in advance.
Thanks in advance.
