Power Fold Mirrors not Working
imnuts
Dirty Jerz
'21 502A Powerboost 4×4
Facilities Engineer
So this morning, I pull out of my driveway and realize my side mirrors are both folded in. Not sure when it happened, but I tried pushing the fold button on the door and nothing happened. Put it in park, still not working. Rolled down the windows and just manually pushed them out. Tried to use the fold button again at work, then again when I got home and it's still not working. I read the manual, tried the suggestion and nothing. Everything else on both doors is working as far as I can tell, I don't know why the side mirror button isn't.
I thought it may have been something with the Forscan changes I made yesterday, but that was too the BCM and APIM. I checked my BCM changes again tonight, everything lines up with the Forscan spreadsheet for what I wanted to change. I went back and also checked the DDM & PDM and coding for the mirrors looked fine there.
Does anyone know what the issue may be and how to fix it? I didn't see any fuse dedicated to the mirrors in the manual, but if there is one and someone knows the number, I'll check that.
WD8CXB
South Amherst, Ohio
2023 F-150 4x4 SuperCrew / 2020 Expedition MAX 4x4
Electrical Engineer
Don't have the same problem as you but still a problem with the mirrors. My mirrors do not always unfold all the way. I took it to the dealer, and they said it was the switch. However, the switch is on backorder. To fix the problem, I have to unfold the mirrors manually.
imnuts
imnuts
Dirty Jerz
Facilities Engineer
Got my mirrors working again. I toggled auto-fold back on in Sync and the button started working again. Thanks to ddb on F150 Forums for the suggestion.
Steeler
New York
2021 F150 Lariat; 2022 F150 Limited
Not to rehash an old thread, but I had the exact same issue. Toggling the autofold back on fixed it. Thank you!
