Possible to unlock all doors when driver door opens?
WhiteLightningnshitshadow
Lead Engineer
Is it possible to use forscan to change how the locks operate? I usually have my kid in the back. I get out of the front door and often find the backdoor still locked, which is very different from what I'm used to with the SCAB suicide doors. Any way to change this so I don't have to reach for the unlock button?
I assume truck is still running when you hop out so the auto unlock isn't doing it.
I was annoyed by doors locking automatically so did the Forscan change to put auto lock option on sync screen and turned off.
Lead Engineer
Actually it's when the truck is turned off usually.
EBR
MN
07 Lincoln Mark LT, 23 F-350 Platinum Diesel
Hopefully this is what you are looking for. In the 2022 manual:
AUTOUNLOCK (IF EQUIPPED)
WHAT IS AUTOUNLOCK
Autounlock is an unlocking feature that unlocks the vehicle doors when your vehicle comes to a stop.
AUTOUNLOCK REQUIREMENTS
Autounlock unlocks all the doors when all of the following occur:
• The ignition is on, all the doors are closed and your vehicle is moving at a speed greater than 12 mph (20 km/h).
• Your vehicle comes to a stop.
• You open the driver door within 10 minutes of switching the ignition off or to the accessory position.
SWITCHING AUTOUNLOCK ON AND OFF
1. Press Settings on the touchscreen.
2. Press Vehicle Settings.
3. Switch Autounlock on or off.
Lead Engineer
WHAT IS AUTOUNLOCK
Dude you're the damn man. Thank you. I'll look for it next time I'm in the truck.
B17drvr
Tim
Southeast Texas
20 F150,14Fiesta ST,15 GT350,13 Boss 302,21Mach 1
Pilot
The answer is in your manual. Or, just go through the settings menu.
Never had the unlock work in a way that I liked so disabling the auto lock was solution for me. :)
