SuvE
I changed my oil this morning, and when I went to reset the oil life monitor on the display, it won't reset. Normally you get to the oil life display under engine information, press and hold the ok button, and after a few seconds it will reset. Not this time. I held it down for over a minute... nothing. This is the 5th oil change, and this procedure has worked every other time. (Platinum, 5.0 V8, 27k miles) I tried several times, with and without the engine running.
About a week ago or so I got an OTA update that claimed to address a potential non start condition. It didn't say, but I suspect it was due to the no start when oil life is below 20% and the oil level is low. Did they fix one problem and break the reset in the process? Did they change the reset procedure?
Has anyone else had this problem? I can keep track of mileage the old fashioned way, but I don't want the nag to start when the percentage gets below 10%.
Does anyone have a solution?
