OEM Carpet - ruined?
Avalanche24PB
2024 F150 Powerboost
So... 2024 F150 crew, black interior.
My lazy a$$ said "it's only a mile" and I put 3- 5qt jugs of used oil on the rear floor liner. Made sure caps were good and tight. Turned a corner and my son says "Dad it's leaking!" Cap popped off and 3 quarts spilled... a bunch overran the floor liner and got under the passenger seat and drained down where the wiring harness runs under passenger doors. Turns out, I had tightened the cap just enough it was barely hanging on. I could "strip" it pretty easy by just giving it a little extra turn and it would pop off. Talk about a bad day...
Pulled the passenger seat and used hot water and Dawn Powerwash to get the most oil I could... and you can't see the oil due to the carpet being black, but I suspect it will forever smell like used oil. So I'm thinking just rip it out and replace it.
Couldn't find an OEM part for the floor carpet liner, maybe I suck at searching on Ford Parts site?
Any experience with this, tips, or a part number would be appreciated. Thought about junk yards but might just end up calling the dealer. Lazy/stupid is expensive...
Kanuck
Winnipeg, Manitoba
Retired Electrician
You could try talking to a restoration outfit and see if they have a way of removing used oil from carpet. You could get some, I call it Absorb-all, I use it in my shop to soak up any fluid that gets spilt. It lifts oil of the floor very well.
Big Dog Daddy
New Jersey
The basic Ford part number for the carpeted rug including the backing mat that is glued to it, is ML3Z-1613000-xx , were the xx suffix is replaced by letters that are vin specific. Example, your carpet may be ML3Z-1613000-AC. You may have to purchase and pick up it at your local dealer its bulky and expensive to ship.
Ford F-150 OEM Carpet - ruined? Screenshot 2025-05-27 155613
Carpet Floor ML3Z-1613000-AC | Varsity Ford
Avalanche24PB
Ah... so the Vin part is my problem! That part number had appeared to be tied to an older model truck but this makes more sense now. Thank you.
Looks like I didn't save any money doing my own oil changes after all LOL
