MTMan
- Joined
- Oct 11, 2024
- Threads
- 25
- Messages
- 723
- Reaction score
- 1,004
- Location
- Big Sky Country
- Vehicles
- 2022 F150 Lariat FX4
You're up there a bit, eh?
| Part Number | Part Name | Price | Quantity | Total |
| ML3Z-2078-M | Flex Hose | $91.06 CAD | 1 | $91.06 CAD |
| ML3Z-2078-P | Flex Hose | $106.62 CAD | 1 | $106.62 CAD |
| BRAB-646 | Motorcraft ABS Sensor | $123.96 CAD | 2 | $247.92 CAD |
| HL3Z-3A130-A | Outer Tie Rod | $83.37 CAD | 2 | $166.74 CAD |
| W712104-S439 | Upper Control Arm Bolt | $14.84 CAD | 2 | $29.68 CAD |
| W715151-S440 | Strut Nut | $14.82 CAD | 2 | $29.64 CAD |
I've seen a few swaps where they just re-mounted the stock brake lines to make them work.Do Raptors have longer brake lines because it is taller and wider? For 3in lifts I have not seen anything about needing longer lines.
if you wanted to rebuild the Raptor shocks as they are, you need some expensive tool, they have a ridiculous way of doing the nitrogen charge. Thankfully, this kit comes with shreader valve adapters, so you can charge with a standard air chuck and nitrogen. There are some tools needed to disassemble and re-assemble, but for the most part they are standard shock servicing tools.Do these a have a nitrogen charge or something you can do at home? I’m not familiar with this set up.
