Column mounted shifter? Brake pedal interlock failure? I am not familiar with this yellow cable that you mentioned. Sounds like fuel pump failure or something that is not turning on the pump. Hello dealer. Good luck.2023 xlt 3.5 wont start just turns over really fast it is also locked in park can't release with yellow cable either has half a tank of fuel was running perfect this cam out of nowhere any ideas
Sounds dumb but check and make sure your floor mat isn’t on the gas pedal by accident. Make sure the gas pedal is completely free.2023 xlt 3.5 wont start just turns over really fast it is also locked in park can't release with yellow cable either has half a tank of fuel was running perfect this cam out of nowhere any ideas
