rugedraw
I already tried to check that, but your car has not reported itself to the cloud since 4/18. If you have FORScan, plug it in to see what codes are there. Clear them if you want. If the code is still there but everything works, then ignore the code. Notice how there were two SSM's referenced by the code I showed you earlier? Here's the other. A code is not a problem......only a problem is a problem.Definitely. Do you think the error that you found will go away now or do I need to clear errors with FORScan?
