New wheels and tires help...
MHaynes772
Matt
Nashville
2021 F150 Platinum
Im looking at getting the Venom 601 wheels with Nitto Ridge Grappler tires for my new Platinum. Im going to be putting a 2" level kit on the front and wondering what the largest tire I can fit without having to do any modifications. No rubbing or cutting anything to make it work.
Appreciate any help!
Ford F-150 New wheels and tires help... Screen Shot 2021-06-03 at 10.29.21 PM
Daily22ssv
Adam
Tx
21 F150 powerbost
Tech
I put 295/60/20 on fuel blitz 20 offsets on had slight rub on lower air dam driverside when turning. It could easily be trimed. I end changing tire to the new nitto recon 385 55 20 and rides better getting better fuel mileage as well.
Ford F-150 New wheels and tires help... 20210517_000641
Daily22ssv
Adam
Tx
21 F150 powerbost
Tech
Wrong photo that's the 295 60 20 G2 nittos.
Rich1982
Rich
Kansas
2021 F150 XLT/302A
Semi retired
Going to watch this thread - I have Nitto Terra Grappler G2's in 275/65r20 on stock wheels/suspension, but thinking about going to the Venomrex 602 if/when they go on sale
MHaynes772
MHaynes772
Matt
Nashville
2021 F150 Platinum
I don't know much about tire size. I keep seeing 285/60/20, some 285/65/20. Not sure what to go with.
Anymore suggestions of input, fire away.
Knickell
Mazda Protege, Ford F-150
Not sure about the tire size, but that Venom 601 is a sharp wheel. Nice choice!
jfritzke26
Wisconsin
2021 F-150 Lariat Powerboost FX4
Teacher
You didn't mention what size wheel you'll be buying, so it's hard to recommend a tire size.
I had 275/60R20s on my truck from the factory, which had an outside diameter of around 32.8 inches. I switched to a 17 inch wheel with a +25 offset (compared to factory +44) and 33x12.5R17 tires and have no rubbing. The 33x12.5 tire I selected is also 32.8 inches. I don't have a lift or level.
So with a two inch lift/level, you should comfortably fit any tire with an outside diameter of 33 inches. Go to https://tiresize.com/chart/ and scroll down to tire size by diameter, select 33", and then check the different wheel sizes for a variety of tire sizes that equate to 33 inches.
Ford F-150 New wheels and tires help... Screenshot_20210625-181805
It's up to someone else to say whether a 34 or 35 inch tire would fit.
BoostedECO
New Jersey
2021 Ford F-150 XLT FX4
I was thinking about going with the 601's on a 20x9 +12 on a 305/55. The Mizler Bro. on Backroad Driver went with the 602's they fit with trimming of the plastic valence.
bosro
rod
Alberta Canada
2017 F150
There's tons of tire size comparison calculators on line.
https://tiresize.com/comparison/
This is just one.
In a nutshell the 285/65 is going to be same width,taller,and have more sidewall(distance between rim and ground).
Some calculators say recommended or not to the different tire sizes.
Larrymoe
2024 F150 XL RCSB
This post was from 4 years ago.
The OP hasn't been on this site for 3 years.
