NEW Diode Dynamics Headlights
dolsen
KY
2022 Rapid Red 701A
I know right? There’s two open connectors so maybe the front and rear connect here?
I’m guessing it was a mis build. The right front ride height sensor is only present for scales and/or CCD. You aren’t the only person to report ride height sensor connectors without ride height sensors attached
SnareDrum
Connecticut
2022 f150 lariat
Wonder if I could just order the sensor and plug it in after getting the hcm?
dolsen
KY
2022 Rapid Red 701A
It’s certainly possible, but you have to figure out at what connector the wires terminate and then finish the wiring all the way to the HCM. It’ll cost you a lot less time and headache and only marginally more money to run the wiring on your own
EDIT: just remembered this is the passenger side sensor. It isn’t used for auto leveling headlamps, so it’s of no use unless you get scales and/or CCD and a VDM
SnareDrum
Connecticut
2022 f150 lariat
You’re right, seems like it’s more practical to run the wiring. Thanks for the deets
