Need Hitch advice
CindyC-IL
Cindy
Illinois
F150 Lariat
Business Systems Analyst
All, Hope you can help with the following. Looking for weight distribution hitch recommendations/advice with the following criteria.
Have 2021 F150 Lariat 3.5 v6 Ecoboost.
I'm renting a trailer for an upcoming trip (about 1400 mi round trip). Planning to pull 22' trailer with GTW of 4830 and Tongue Wt of 430
The person renting from does not have a Weight Distribution Hitch (WDH). The weight looks to be just under what is allowed for towing without a WDH, I'd rather use one for comfort and safety.
The problem is I will need to purchase one and it has to be one that can be attached to the trailer without drilling holes. We plan to purchase a trailer in the near future, about this size or a little bigger, so if I purchase one and I like it, it would be useable in the future.
Any suggestions, advice, caveats are very very much appreciated.
Thanks
Cindy
UGADawg96
JAX, FL
For that weight, I'd be more focused on sway control versus weight distribution. <500lb of tongue is manageable. I'd be more concerned with passing trucks with that sail. Is the owner of the TT okay with you bolting bar attachments to their frame ?
Mash150
Dale
North of the 49th
21 King Ranch, 157, SQ , PB
Thanks
Cindy
If you have sway control on your truck, you sb fine with that hitch weight for your trip.
Buyer2021
central TX
retired!
There are plenty of WDHs that don't require welding or drilling for fittings to the trailer tongue. If you don't have access to a competent hitch-shop then etrailer.com can be a useful resource (call or email for tech support). Three things you need to consider (and know to share with whoever you consult for advice):
  • The cross section of the trailer tongue (the 'a-frame'); is it C-channel, rectangular boxed, etc and the height & width dimensions of that metal frame member.
  • The distance from the center of the hitch ball to the front and back of propane bottle racks or anything else that would interfere with a WDH bracket which rests over the top of the a-frame (you'll need a 'clear spot' for the WDH bracket in most cases)
  • An estimation of the actual loaded-for-travel total and tongue weight of the trailer (NOT the same as the manufacturer's advertised data)
With the above info you should be able to find a suitable WDH - the installation instructions for all WDH's will specify the types of tongue cross-section that they are compatible with and will specify the distance from the ball center to where the brackets should be mounted (that 'clear-spot' you'll need on the a-frame); it's likely not all WDHs will be suitable but you'll find at least one that is.
Keep in mind that there is no benefit and in fact likely detriment in 'oversizing' a WDH - make sure that the WDH is rated for the range of trailer / tongue weight you will actually be towing, not a heavier trailer. Just like vehicle springs the WDHs tension system needs to be rated properly to the load, too-much 'spring' will introduce harshness and may over stress the rig, all to the detriment of towing ease and safety.
A comment about sway ..... the long-proven and IMO best way to prevent a propensity to suffer trailer sway is proper trailer weight distribution. You need no less than 10% of the actual total loaded-for-travel trailer weight on the hitch. This rule, referring to the trailer weight distribution without a WDH engaged, applies even when a WDH is used to correct the 'sag' induced by adequate tongue weight. IME with proper weight distribution and a decently engineered trailer no 'add-on' sway control device is needed.
Hope that helps, Good Luck, Happy Trailering!
notabot
Americas
Yes
Open or enclosed trailer? Is it a big box/rectangle or are there any aero features to cut through the wind?
EricR
Eric
Boise, ID
The Sway Pro from Blue Ox has been great with our Lance 2285 (22ft) trailer.
We were caught in a severe windstorm in Utah and suffered no sway while driving to where we got off the freeway. The truck and trailer did get blown side to side together, but acted as a single unit.
https://www.blueox.com/swaypro-weight-distributing-hitch/
Features:
  • Evenly distributes weight over axles of the tow vehicle and trailer
  • Noise-free sway prevention never stops working, even in rain or snow
  • Caster in the hitch head constantly centers the trailer
  • Spring bars augment the suspensions of the tow vehicle & trailer
  • Rotating latches with clamp-on brackets for quick and easy setup
  • Powder-coated steel construction
SuperRaptor
2018 Lariat 502A
If you're driving through flat areas towing that little weight I'm going to say you're going to be just fine. A 22' trailer isn't very long either.
kevdog0710
Kevin
South East Pennsylvania
2022 F150 Lariat Supercrew
Union Carpenter
I have Equalizer brand on my camper. No drilling at all. Its a little noisy, but has sway control built into the weight distribution system. Once it's set up there are no further adjustments like you may have with a chaim style system.
I agree with a previous post, you probably don't need anything for the weight and length of your rental.
CindyC-IL
Cindy
Illinois
F150 Lariat
It's a travel trailer. We are driving from Minneapolis to Eastern Montana in mid October.
notabot
Americas
Yes
Length is only one factor, you also need to consider the frontal area and how much sail area is on the side. My travel trailer is 29' long and the stability of the tow is manageable with a WDH. When trucks or other large vehicles pass on expressways, the TT catches a lot of the wind and usually does start a wiggle. No expressways? IMHO, no issues.
