XLT22
- #316
Antenna plugs are male, splitter plugs are female and body harness plugs are female so no that won’t work. Since you’re already buying the antenna, it makes no sense to buy an additional splitter when taking apart the stock antenna is free.If you were just looking to add XM, could you install the new antenna and then install the splitter at the headliner? The curry plug from the antenna would go into the splitter. After the split the curry plugs into the curry on the body harness, blue plugs into blue which runs to the TCU. The maroon from the antenna connects to the maroon which runs to the TCU. An extension FAKRA would run from the ACM to the glovebox curry plug. This, in theory, would give you XM and retain the GPS for FordPass at the TCU without having to disassemble and tape the old antenna to the inside.
The unknown is whether the GPS signal after the split is the same for the TCU and APIM...
