Sbdavis1
- First Name
- Stephen
- Joined
- Nov 20, 2020
- Threads
- 4
- Messages
- 125
- Reaction score
- 206
- Location
- Fayetteville
- Vehicles
- 2010 F150 Lariat ordered 2021 F150 Lariat
- Occupation
- Financial Planner, Lawyer
I have a 502a PowerBoost Lariat and had the same issue with the rain sensing wipers. I had it toggled to what would be on for every other setting and nothing in a downpour. They just sat there no matter what sensitivity I set it to. I moved the slider to the left off position and voila it worked. That’s a pretty bad miss on the build and quality control that it never got noticed anywhere along the way. They definitely reversed the off/on switch position for my rain sensing wipes as well.Well, things aren't fixed...
The driver side fog light still goes off and on. This now seems to possibly be a mechanical issue as they have done software updates.
I am not sure about the Auto High Beam issue just yet as I was only driving around in my area which is light very well. However I did notice the fog light going off and on.
This is weird. So I have all my settings that I want on set with the toggle switch illuminated (button to the right and blue), I know this from other functions that work, like the auto fold side mirrors. However my issue with rain sensing is reversed. If the toggle button, to what I "assume" is on and is illuminated (the button is on the right and blue) rain sensing does not work. However if I toggle it off (grayed out) it works. But functions that work are illuminated blue with the button to the right. Regardless something seems flipped.
I am not convinced the lane departure warning works since nothing happens if I cross a line with or without the turn signal on. But again it is blue not gray. It was set to normal then high sensitivity with no reaction from the vehicle. I am not sure what triggers that feature but will check that out.
Then today I set on cruise control, I use adaptive, I got a warning that the front camera failed and needs servicing. So I flipped that off. However the camera appears functioning when I parked. And then later on when I put cruise control back on, the message did not reappear. It seems to be fine. But this does not make be feel comfortable.
I have all the collision warnings etc set to on. But how do I even know they will work.
They did not do anything with the axle rust, as he said it was just surface rust and I could wipe it of. Apparently they could not do this, during the 4 days in was in their possession. If this was my only issue I would not care. But this now seems annoying that Ford thinks this is something I should take care of myself. I am sure this isnt a feature on GM or Ram.
Also I am not sure but I would expect a loaner vehicle for extended stays especially on a brand new vehicle. This was not offered on the first 4 day lay over, I will ask next time. Though they may not have thought it would have taken 4 days, I would think that would just be a consideration on a brand new vehicle as a courtesy.
So I will call in on Monday and perhaps Ford's customer care, if I can find that number.
